x
Are you trying to run Aisin Hubs? Why are you changing out the hub gear/ring? Yes, if that is the case, you need the shorter Birfs. I run a '77 small pattern on my '66 and run Aisins and the shorter birfs. All is OK.
Ed
You can sell your current lockout hubs and birfs for enough $$ to make the switch and then some.
You do not have to change the knuckles or hubs themselves, just the birfs and the lockouts, however if you're going to longs for strength, I assume you have power steering, so you'd better have large-pattern knuckles. :eek:
