Note: This feature currently requires accessing the site using the built-in Safari browser.
Looking at going full float in my new FJ55 and I think I've narrowed it down between these two choices. Not being considered are the D60 and 14 bolt. I know they are options that are out there.
With the FJ40 full float, I note the following:
With the FJ80 full float, I note the following:
- $450 from SOR with no brakes and probably needing a full rebuild
- I've heard issues with leaking
- Brackets for disc brakes are different than standard semi float. SOR sells kit... downey sells brackets for about $150.
- Not clear how much are special items and how much are go into the local Napa autostore for parts
- Still need to figure out mechanical ebrake. $200ish for El Dorado calipers.
So, what am I missing here?
- Comes with rear disc brakes AND parking brake
- Too wide. Need to chop about 7" off. I have a guy who will do that for $100 a side. Does not include axle shafts. Is it possible to just pull 7" off the short side?
- Potential of having electric locker in it
- Potential of not needing to be rebuild given it is only 10-15 years old
- Needs to have all the brackets cut off and spring perches and sway bar mounts put on
Are there any super weak links on the 80 axle I should worry about? Will Tacoma "3 spoke" wheels fit with no mods?
What about the FJ40 full float? Any big issues?
Any opinions one way or the other?
Did a search... found lots of good info. Just not enough to pick one over the other.
Oh and the bronze BJ40 is for sale too, come to that so is the BJ42 in white behind it
Just dug this out, 60 series FF with 35x12.5x15 only stick out this much.
Looking at going full float in my new FJ55.....
It really all boils down to the same answer you'd get if you said why to a guy with a 5000W car stereo....
I won't ever be taking the 55 on anything that needs more than 31s.
