x
The 71-74 boosters have a clamp that holds the two halves of the shell together. All the newer ones twistlock.
The only two external pieces of rubber are the grommet for the check valve and the boot for the pedal pushrod. I have good used ones of both available if you’re interested.
Mark
www.marksoffroad.net
The kit is no longer available for the 70-74 booster. The part that wears out first is the seal on the front pushrod. There have been reports of finding a generic metric seal that fits, but I haven't done it personally.
That being said, the question is"Why?"
No other components of the brake system are Toyota. Why use a small, weak, 50year old booster when there are plenty of new vacuum or hydroboost units that will bolt straight to the GM master?
If you want to send it down, I can have a local shop that rebuilds those boosters for me take care of it: $285.00. They still have parts.
Like @FJ40Jim said, you would need to buy NLA kits for the seals:
