WTF, can this be true?
I had a similar road-side-built intake on my LX a few rigs back and I picked up a maybe 10% increase in fuel economy. Then I built a proper replacement and it went away. My off the cuff conclusion was that I was leaking and aspirating partly without flowing through the MAF. Less measured air, less fuel. No discernible power loss from timing pulled from any knocking from lean combustion high EGTs.
In the end, if you don't know why something's changed, and you aren't able to measure all advantages, as well as potential side effects, its not worth the risk. I'd rather let things run as Toyota designed, for better or worse, than to take a crapshoot, operating blindly, on a mod that presents unexpected side-effects, even if they're beneficial at first blush.
That was just my experience. And my wire and duct-tape intake was far more ghetto than your silicon hose. My gains weren't worth the risk, ya know?
YMMV
I want what George has got. On a more serious note I fitted an intake to my 5.7 ltr V8 which was on your Pontiac GTO's I think. The 4" round and smooth surface made a huge difference in throttle response. Placebo? I don't think so. Not in my 4x4 though. cheers Brian
If you're talking a LS gen motor was it a 'fast 102' intake/throttlebody? Been debating one for a LS3 I've got working up.
@ O.P.-
On the note of this silicone intake/elbow - what was the vendor?
My intake is still the original one, I doubt it has many moons left in it.
If they are cheaper than a OE one, maybe they will hold up for however long the cost payout is - and what boy racer in us can't resist the color palate, right?
This thing cost me 130 bucks off of eBay... I figure it wouldn't hurt since it is only an intake pipe.. I really didn't expect s*** from it but being less prone to cracking, that's it. It just feels different.
No ridges, clean, and overall characteristics, I could see a 1/8 to 1/4 MPG increase. Power increase may not be accurate. Responsiveness may better describe the effect that you are seeing.
I doubt that the tube is doing any change to air velocity....
air being pulled in is limited by the air filter and the tubing before it. Then the velocity of the air changes as it comes in contact with the TB, and then in these engines the upper air chamber and a basically 180* turn towards the cylinders. Then really, the flow of air is disrupted by the valves as it enters the chamber - and has more to do with number and angle of the valves than anything else. If the old tube was able to effectively pull the required air that the cylinders were "asking" for (mechanically) then the change in tubing won't have an effect.
To say that doing it the way it was designed by Toyota is the best, may not actually be true. Toyota builds cars for the masses, not for the individual. Most car owners know little about their vehicles - so Toyota has to build them with compromises such as safety, reliability, comfort, cost to fix/replace parts (etc). As an example - most import 4 cylinders WILL see an improvement in MPG and Performance with a slightly larger exhaust. The "cost" is that it's usually much louder than stock. Most people who buy import 4 cylinder cars won't see the advantage of 2-3% performance/mpg increase at the cost of an exhaust that's 10x louder. That doesn't mean, though, that from a performance/mpg the factory design is the best. It's a compromise.
As far as the intake tubing is concerned, there can be an effect if the distance between the TB and the sensor changes.... that isn't necessarily a desired change, though...
Sorry for the delay Linus to reply to your query. No I have an LS1 with LS2 intake manifold and a Starr 84 mm throttle body. It was done many years ago when things were still quite new to us out here. Of course the mandatory 3" zorst and tune gives it a nice easy 230 RWKS I would love the power and torque in my 4x4 but I have a diesel so will be getting one of those bigboy turbos from Graham.(member here on mud) Pity you don't have these over there as they do have a lot of benefits. Like long range tank allows me to do over 2000 kms. 255 litres carrying capacity. cheers brian
sorry for off subject a bit......
