Wouldn't accelerate after 2hr traffic.
Temecula
Yesterday I was comming back from a Baja trip and all went well until the border. I was stuck in the typical 2hr 0-1mph traffic and all was ok, not hot, running fine. Then when I went to speed up to highway speeds the engine started to miss/ cut out and won't get much past 40mph. I pulled over, turned it off, all looked ok, so I started it back up revved it a few times and took off for another 100 miles with zero issues. Any ideas what would cause this? It has me worried.
Howdy! Sounds like an old fashion vapor lock. Fuel gets hot enough to "boil" so that the pump cannot move it. Not too common on newer vehicles with higher pressure fuel systems like EFI. Electric fuel pumps in the tank usually don't have this problem. John
Possibly bad gas - where did you last fuel up? How's your air filter? Just a couple of ideas.
I guess it could be?? I didn't even consider it. The underhood temps didn't seem too bad when I pulled over and opened the hood, but the cooling fan thing was on. I guess the slow moving and the exhaust heat right by the fuel. The out side temps were probably in the high 60's is all. It did have the same feel as when I had a old fuel pump filter that would plug up once the fuel got hot. Thanks to this board I got that figured out.
probably a long shot, but maybe it was the ecu relearning. ie you were stopped at almost idle for a while so the computer learned to give less gas. Both of my cars seem to do this after driving at the same speed on the interstate for a long time.
but then again I dont know much about older efi setups.
The computer is smarter than that.
Uhhh...no.
The pre-filter is a soft, flexible mesh cone that sits on the intake to the fuel pump. Once it gets clogged and the fuel in the tank warms, it will collapse on itself and block the intake to the fuel pump. Shutting down the motor allows it to expand back into shape. Once you start driving, the length of time it takes to exhibit the symptoms will vary with temperature of the fuel in the tank, throttle input, and the amount of fuel that the pre-filter can flow.
FWIW, this is very common on older 80 Series. Again, they should be replaced every 100K miles.
Is this your problem for sure? Idunno. Given the symptoms and age it is the first place I would look.
The prefilter has been replaced. It was previously bad though. That is how it was acting though even if breifly. Before I replaced the prefilter once the gas would heat up it would keep missing and running rough until the gas in the tank cooled down. What got me is after I shut it off and restarted it has been fine. Not even a miss. The gas was an off brand that I got at the border but it ran fine before and after. The air filter is pretty new also. Could it be some kind of sensor that needs cleaning or something? 02 sensors are new. A hard problem to diagnose since I rarely sit in almost still traffic for 2 hours.
DOH! Sorry. Didn't see that post. I got nothin'. Vapor lock is highly unlikely as the fuel line is pressurized. You were idling most of the time which is a light load on the motor and with the ambient temps it was probably running cooler than on the highway.
Was she really cutting out/stalling or simply no power?
Well it was trying to go but would kind of chug or something was keeping it from speeding up. Felt like it used to before I fixed the prefilter. Hard to describe but obviously a problem. The extended ideling must have done something.
Any chance a small amount of air is leaking somewhere past the MAF or something causing it to get confused only after an extended amount of time sitting at the same rpm? Just guessing how something must be compiling to cause a problem.
Typically, unmetered air shows up as rough idle or stalling. As soon as there's throttle input it clears right up.
Hey, have you changed your fuel pressure regulator? This will show up as hard starting when hot, but could cause a host of other issues. Just guessing at this point, but fuel pressure and vacuum come to mind. I'd poke around the engine bay for a while.
Never changed the FPR. Never had a problem starting either. Probably starts easier, if thats possible, when hot.
I'll check around for a vacuum leak, maybe replace some of the older hoses.
I've had the same experience with hot engine bays in turbo cars in extreme stop and go traffic, not really high ambient temps. An overheated coil will exhibit the same behaviors you describe. Once the underhood temps went back down, problem went away.
Haven't heard of this problem on the 80, but all oil filled coils can overheat, causing misfiring. Corrected by a cool down or more airflow.
HTH
Scott J
94 FZJ80 Supercharged
Never thought of that either but the coil is pretty far away from any heat in an 80. I have had that problem in my old VW. I wish I would have felt it to see if it was at all hot. I usually have a totally different diagnostic frame of mind when I have trouble with my Bug compared to the Cruiser. I also started to get some online paranoia after reading about the EFI relay. I may try upgrading that before anything goes wrong.
Just a small update but after staring at the thing for an hour or so with a flashlight all I found was one of the dist. cap vent hoses was off. The one that runs to the top of the air cleaner. Would that do anything? Seems like little to no vacuum is on that hose.
