Workable Tailgate and Associated hardware.....
Utah
I am looking to install a soft top and would like to add a workable tailgate, just wondering what others are doing for the hinges and hardware?
Made my own from two old barn doors and made the hinges, latches, chain hangers from flat bar, tubing, and angle.
They look great, did you use tube for the lower hinges or roll the steel, do you have bushings in the lower hinges? Where did you source the LH acting hinge?
I have a set of good barn doors I was going to sell or trade, maybe I'll just use them and create a tailgate.
The hinges are tube welded to flat bar. I considered putting brass bushings in the hinges, but decided it wasn't necessary. The latches are OEM, but the left side is no longer available. You can take a right side latch and convert it to left side. The most important thing, I think, is separating the front and back of the barn doors and welding a 1/2" x 1" rectangle tube figure-eight frame in between them along with 1/4" pads for the hinges, latches, and chain hangers. It makes the whole thing rock solid.
There is also this option from Real Steel. I think it might be a fairly new offering. I want to figure out how hard it would be to adapt latches that leverage the ambulance door mounting bolts so I have the ability to switch between hardtop with ambi doors and soft top with a usable tailgate.
its been out a few years...i went with one back in 2017, and love it everyday.
i also used btb aka man a fre hinges.....in hindsight i could have just made my own as well
This will only work with obd2? Yeah?
Would you mind sharing some pics of your tailgate? Do the BTB/Man a FTE hinges bolt up to the real steel tailgate without modification? How did you handle latches and tailgate cable/chain?
The real steel gate is a repo and the hinges are repo...so everything lined up there.
Latches I tracked down decent used.
Made the catches.
Pretty sure I got btbs chain kit as well...which was also a waste of money for otherwise readily available stuff.
The rubber sleave is just a bicycle intertube.
On my last 40 I did just that, I made the latch portion bolt to the original ambulance door bolt holes so when I went with the hard top I could run the ambulance doors. For the bolt holes in the rear seal I just put the bolts back in when the tailgate wasn't in use.
Scott
Found the hinges on BTB's website, but for that price I think I'll be building my own. Was hoping they'd be about half what they are selling them for. Oh well, so much for saving time. I still haven't been able to find the LH latch. Has anyone done anything different for latches?
Scott
That is what I plan to do, do you have pics of your latch plates? I just looked up the BTB hardware...I think they are gold plated...$705 after tax for a full set of hardware.
yeah they have definitely gotten pretty proud of their stuff. i was in for a hundred on the hinges....
As mentioned, the right side latch is still available (I think, been a while), so you get two rights and convert one to a lefty. This is one I did a while back to check feasibility. Sorry, the second photo is pretty crappy. I separated the latch portion from the mount portion just below the slot, turned one side around, and welded it back together. It turned out fine.
[QUOTE="DieselFJ, post: 13067246, member: 52311I still haven't been able to find the LH latch. Has anyone done anything different for latches?
Scott
[/QUOTE]
Scott
[/QUOTE]
That is a pretty good solution. Now to find the right hand latch part number.
Attached are the best pictures I could find.
Scott
Might check out @darwink1 build. He reused a Hilux tailgate. I think @letterman52 did one similar. I like the idea of the center handle. The stock tailgate is cool too, but like the custom touch.
