No really a roll over but the truck landed on its side and now the engine will not start... any idea's of what to check in order to figure out this issue? Towing company disabled the transmission linkage, thats all thats been messed with.
Reconnect the linkage. Will it turn over? If I lived anywhere near there and could get it for what eBay has it listed for currently it would be mine
Sent from my Nexus S using IH8MUD
Oil went into the valves. Don't try and start it our you will break something from too much pressure. The oil needs to be removed before it can start and don't forget to add oil when you get the other stuff out. Its called hydrolocked.
You need to pull the spark plugs and suck out as much ouil as you can. Then bump start to let the pistons push oil out. I would also find someone who has don this to give you more information on how to do the job right
) I actually had a small fire to put out, lesson learned.
I hope this helps anyone who may encounter the same misfortune I did.![]()
