1972 fj40 with a 76 2f engine, got it running really nice but noticed today that the lower crank pulley is wobbling badly. I shut down the engine and there is a bit of play when you push up and down on the crank pulley in the direction of the belt, about 1/8 of an inch. Had a friend look at it and he seemed to think that the crank is probably fine but the crank pulley needs to be replaced. Do the pulleys wear out inside? OR does the key wear out? I read some threads and it seems that if the key is bad it can be replaced or the crank can be welded to the pulley, also read that someone drilled and put a bolt in there? Pics of these fixes would be appreciated. I REALLY DONT WANT TO HAVE TO PULL THE ENGINE. Never had have to deal with this so all opinions appreciated about what might be going on here. I plan to try to pull the front nut off tomm, gonna have to find a 46mm socket locally though.
Noah
Noah
