Wits-End abs plugs
I do not make the ABS plugs. If they're no longer supported I could make them, but I have no interest in hijacking a product from someone already making them.
I swear I've seen that someone on here is currently hmm maybe they will chime in .
Should just go in the hole and bolt in with one bolt
That's all you have to do. Simple and only need a 12mm wrench for install.
I've done the cheap approach which is just cut down the sensors leaving the cap to plug the holes. I'm working on a pair axles with deleted ABS and I searched for plugs to fit the holes. One is 17 mm diameter and the other 20 mm diameter, rear and front respectively IIRC. The Dorman catalog did not have anything that would work. I found some 17 mm plugs somewhere but would have to buy ca. $25 worth, not going to do that. I back to hacking up some OEM sensors to plug the holes.
