wiring
Hello all,
Just wondering if anybody, would have a simple wire diagram kicking around, i need to rewire the landcruiser, as the PO, was smoking something out of it, when he did some wiring on this puppy!!
just need the ignition system, and how to wire in the alternator, i look wiring the rest in once i get her up and running.
any help would be greatly appreciated !!:)
Oh yeah, i did a search but didnt really find anything helpfull.
its a 1978 fj40, manual.
Cheers
that ignition is all upside down isnt it? :frown: start switch seems to just go to the radio,
is there a differance between a US made Cruiser and a Cruiser made else where in the world, such as New Zealand. ?
as mine does not have a lot of the guff that, that diagram has, i do not have an ignitor, my distributor has only one wire for it that plugs into the negative of the ignition coil, and my starter only has two wires, one that goes to + on batt, and one that leads off to start on the Ignition switch.
The start and ignition sides of the switch and the wire color codes are flipped in that diagram. Other than that it is pretty accurate for US cruisers. Non-US cruisers don't have some of the things, but you should be able to figure it out as the rest of the wiring will be the same.
I would suggest purchasing the wiring harness from painless and rewire the whole truck while using all your adapters. I know it's a PITA, but the wiring harness from Painless, is well fairly painless.
Thanks.
Pegasus;
I'm assuming that u have a points type of distributor. I wonder what type it is?
Does the FJ40 have the original coil in place?
U could try the hot wire method. Positive battery to the positive side of coil; crank the engine; maybe will start.
That may get things moving and then we move onto the wiring and what condition it is in...
