Wiring question
San Diego
My interior lights don't come on when I open up the rear hatch.
I've tested the hatch switch, and it works fine. The problem is that there is no voltage on what should be the hot side of the switch.
The other doors do activate the interior lights, so I know I've got power past the last fuse.
I'd like to take measurements at BS2, BR2, and ID2 connectors.
Can someone tell me where these connectors are hidden?
Don't know about all that, but try wiggling the wire harness where it goes from the body to the hatch (upper left I think), and you might be able to quickly see if there is a short there.
Tech_dog;
REF: EWD189U... Pgs 28 & 30
ID2 is located behind left kick panel. 22 pin connector
BS2 is probably behind headliner, upper left rear corner. 3 pin connector.
BR2 is located behind and below left rear cover, near tire jack; 4 pin connector.
Have fun!
