Wiring Question - Batteries/Winch
NOVA
Website
www.flickr.com
All -
So, here is my predicament. I purchased a Warn M12000 as part of my continued effort to build my Land Cruiser and have temporarily hooked it up in a standard configuration to my primary red top Optima (34R). However, I am wanting to integrate it into my dual battery system. So, I purchased a Blue Sea Systems 3002 battery switch. The switch is capable of being in the following positions:
  1. Position 1 - Off
  2. Position 2 - Battery 1
  3. Position 3 - Battery 2
  4. Position 4 - Combined
So, what I was planning on doing was wiring positive wires from my primary and auxiliary battery onto the switch (Battery 1 and Battery 2) and then wiring the M12000 positive to the ignition post. I am hoping that this would allow me to have a manual switch to turn power to the winch on and off as well as use either battery or combine them.
The question I have is...will this work? In other words will running two positive wires (from both batteries) to the switch and combining them burn out my M12000 since I would not be using a solenoid in the system.
Also, what should I do with my negative wire from the winch? Should I buy another switch and do the exact same thing except with the negative wires or can I just connect it to one battery?
What I am trying to do is completely isolate my winch from my dual battery system (Painless) and give myself the ability to turn power to the winch off manually.
Thanks guys...I am shaking my head on this one.
Cheers.
- Mark
In the FAQ
https://forum.ih8mud.com/80-series-tech/84888-faq-80-lx450-may-2009-added-rotf.html
you will find a link to the dual battery FAQ
https://forum.ih8mud.com/80-series-tech/104630-faq-addition-dual-battery-set-ups.html
Lots of information in there.
You're describing 1/2 of a setup... i.e. how the winch hangs on the system. How are you charging your secondary battery?
Do you have any plans for putting fuses on the cables that will feed that switch? Picture one of them rubbing/loosing shielding and welding itself to whatever it rubs on... bad picture.
The winch should ground directly to the battery ground(s). The battery grounds should be direct connected to each other as well. Don't rely on a body ground to ground the winch or battery to battery for that matter if you're planning to dual feed the winch.
A stick-simple diagram of what you're proposing would help.
IMHO YMMV I'm not a mechanic.
Grench -
Trust me I have read every dual battery setup in the FAQs...however, I have not seen a setup as I am aiming to do. The closest would be Slee's standard dual battery setup.
My dual battery system is a Painless system (see original post) and that is all working great. What I am trying to accomplish is setting up a separate system for the winch.
Please see the following attachment as an illustration of what I am trying to accomplish. What I need to know is this wiring schematic doable from a point of the winch working.
Cheers.
- Mark
Your schematic is fine. You will be drawing the full current through the power and ground wires connected to the switch and and ground cables respectively and half of the current (give or take) though each of the two cables connecting the batteries and the switch. Have you verified that your switch is rated to handle the load of the winch?
The item missing from your diagram is the the ground cable on the batteries to the frame. You will want those to be large cables as well as up to 50% of the current flows through them.
Edit: my references to current flow were based on setting the switch to off or both as I cannot see a scenario in which you wouldn't want the switch set to both while winching.
... Trust me I have read every dual battery setup in the FAQs...however, I have not seen a setup as I am aiming to do...
This is pretty much exactly what you are trying to do: george4wd.taskled.com/auxbat.html except you've got the Painless setup in place of his solenoid.
There is additional discussion in this thread: forum.ih8mud.com/80-series-tech/300724-dual-battery-question.html.
Tricky -
Thanks. I think with my setup that I won't need to run a relay to disconnect the solenoid. I am assuming this because the Painless system is running separately...is that correct?
The switch I picked is rated for 500 amps continuous, 700 amps 5 minutes, and 2,750 10 seconds. I think this will be OK for the M12000.
What size wire would you recommend running from the battery to the frame and from the battery to the engine block.
Cheers.
- Mark
In your case, the Painless system is taking care of keeping the batteries charged, so the Blue Sea switch is just for disconnecting the winch or selecting which battery to winch from. When you winch, I'd set the Painless toggle switch to the isolation position so that you don't draw any winch motor current through the Painless relay. Just remember to set it back to the charge position afterwards so you charge up the batteries. The purpose of extra relays in George's circuit is so that you don't have to remember to do this - it happens automatically.
According to the Warn web site, the M12000 can draw up to 440A at 12V, so you should be fine with the switch you have (rated for 500A continuous).
The larger the wire gauge, the less wasted voltage loss due to resistance in the cable. 1/0 AWG drops less than 1/2 volt at 400A over 10 ft, so I'd use that between the battery and the engine block if you can. You don't need that big for battery to body, since the current draw from devices grounded via the body (e.g. light blubs) is far less. 6 or 4 AWG should be just fine.
TricyT -
Awesome information...I really appreciate it. I'll go with 1/0 for the switching and battery/engine block and 4 for the battery to body. Thanks again.
- Mark
TricyT -
- Mark
IMHO... a winch, with it's ~450amp draw should be grounded directly to the battery it's drawing from with a cable just as stout as the one connecting to the positive pole, maybe even bigger.
I have two switches that are older versions of the one you have. I use one dedicated to the winch, the other dedicated to everything else. Does yours self illuminate? I.e. glow in the dark without being charged by a light source?
I went with 2/O (OO) marine cables from the batteries + poles to the switches. I used the stock WARN cable to the ignition port on the winch switch. I've considered swapping this out to 2/O, but I keep thinking that I'll want to relocate the solenoid box someday.
The ground side I used 2/O (OO) marine cable battery - to battery - and used the 1ga cable that the winch came with to connect it up to the same post as the 2/O. This makes the electron loop shortest path be on big cables and not through the body or frame.
If you're planning to be able to run the winch off of one, the other or both, be sure of your ground from the winch to both batteries AND from battery to battery.
Making the ground a smaller gauge than the + is a rookie mistake IMHO. Remember from high school science class how electrons are negatively charged?
Electrons flow from the negative post of the battery, through the ground, into the winch(or anything) and then if the switch is closed, on through to the positive post. I.e. it's completely backwards to any form of intuitive reasoning based on what we call them and where we put the switches. BUT - the fact remains that the current flow over the ground cable is higher potential than the current flow over the positive. ground flow of e- into device - work/heat generated by device = + flow into the battery. And yes, that hyper-simplifies it and any electrician can argue the details.
IMHO YMMV I'm not a mechanic nor an electrician.
