I'm getting ready to wire up some lightforce 170's.
I'm thinking that with a little bit of extra effort, I can add the option to make the 170's come one when I flash my brights, and add the ability to dim the 170's and use them as camp setup lighting.
Here's the schematic:
With this setup I should be able to set the brightness level via a dimmer, and then activate the lights via the stock high beem lever or via a new in-dash switch.
I'm trying to decide if it's worth the effort, and I'm trying to decide if the circuit will actually work.
One complexity on the circuit is that I'm going to wire the power supply to the solenoid off of my second battery, which can be seperated from the primary. There may be slight voltage differences between the solenoid control and the solenoid power supply. I'm thinking it won't make any real difference.
Any opinions?
Any opinions?
