wiring help
FJ40JOHN
Cypress, TX
I am working on the complete re-wire on my '77 40, and realized after I disconnected everything, that I have no idea how to hook my dist. back up.
I have the Mel's kit on my stock '77 dist, a Petronix coil, and no ballast resistor. The Mel's kit has a black and red wire. Any help?
I am sure that this will not be the last thing that will stump me in this project, so I'll just make this a general 'I'm in over my head' thread.
thanks...
Download a copy of the schematic diagram for the '78 from the tech links section of this site as it is nearly the same as a '77. It has a couple of errors in it regarding the color coding of the circuits, but it is mostly correct. Using the schematic, look up the color code for the circuit you want. In the case of the ignition, it is a black wire with a yellow stripe. It ended on the passenger fender where the old ignitor used to be. There are two black/yellow wires there: One runs from the starter solenoid and is not "hot" when the ingition key is on. this is the ballast bypass wire and you can disconnect it if you don't have a balast resistor any more.
i have the adobe wiring diagram from the links section. My entire stock harness is sitting on the ground in my garage. a brand new EZ wiring kit is going in. I just can't remember where the red and black wires connect for the electronic ignition (not a stock part, so not on the stock diagram).
The red and black wires on my pertronix go directly to the posts on the coil.
FJ40JOHN said:
<snip>
<snip>
thanks...
