My son in his infinite wisdom chopped his radio harness on our 2002 lx470, mark Levinson with navigation to close to plug and wires keep working loose...anybody have or know where I can buy a new plug with 6 inches or so of wire still attached to fix it
If they are too close to splice you can buy those plastic pinch clamps that you stick a wire in each side and when you close it there is a metal tab on the inside on both sides that allow connectivity. I don’t know what they are called but I used them in my 80 when attaching resistors to my taillights.
Posi-Products (sold at Crutchfield, and on amazon) are the best products for either splicing, tapping, or connecting for car audio. Worth the higher expense as compared to cheap hardware store connectors, they are a superior solution. I will not wire another car audio system without them. Check them out. 1800+ 5-Star rating on Crutchfield.
Pulled radio and wires are fine, getting no sound, no volume adjustment,nor can I make any adjustments in sound menu....navigation and ac working fine...
Checked all fuses I know of, anyone steer me in right direction where to look next...radio was working fine then poof, nothing
More expensive than what ended up working for you! Glad it worked out. The straight answer to your question is, of course, it depends on what you're having repaired. I've used them twice; they refurbed the original head unit in a '93 325i for $150 and guaranteed it for a year. It did fail within the year, and they replaced the entire unit with another OEM one at no additional charge, which worked great for the many years I had the car. If you do need to use them, just give them a call and they'll give you a firm estimate and shipping directions. Turnaround time is quick, too. When I thought I might need the CD/DVD drive or the Levinson amp repaired in my LX470, I called them and the quotes were a good bit more than $150 each. Thankfully, I was able to fix the issues myself (loose change inside the CD/DVD drive jamming the mechanism, and bad subwoofer surround rather than amp problem).
