Wire Identification
Illinois
I have a 1980 Fj40 that I'm putting back together and don't know where these wires go. They are located right behind the tank. I'm pretty sure they are on the same harness as the fuel sending unit. Can anyone help me?
Thanks!
My guess would be off the transmission - reverse indicator light and a ground wire. Can look at my 1980 when I get home if no one else confirms. Pretty sure everything from the tank/transmission area plugs in about half way down the passenger side frame rail.
That would be great. I can't seem to find where they go. The electrical tape on there always makes me nervous too. If you figure it out can you snap a picture with your phone and post?
Thanks again!
Here's what I have on my extra harness. Question for you is this...Are those wires coming from the wiring harness or from under the truck?
Pic of the ground about mid way down the frame.
And pic of wires coming from reverse light - back of trans.
Let me know what else you need??
Further to the back are the tail lights of course, and the wires up to the side marker lights, and the license plate light. I'm thinking it's probably related to running lights or the license plate because I think the solid green in your pic is a constant running light when light switch is pulled to On position.
Hmmm. I remember connecting the ground and the reverse light to the trans. I will have to take a closer look to see where the wires come from. I will get back to you.
If that is a solid green wire then it has to be for the side marker/license light or tail lights.
What I find odd though is the use of bullet connectors for anything on a rear chassis harness on a 1980 FJ40. By then Toyota had went to the nylon 2 pin connectors for the marker and license lights and the 6 pin for the tail lights.
Finally figured out where these wires go. Turns out there was an auxiliary gas tank installed at one time. These wires went to the sending unit of the second tank.
