Wiper motor stop
Butte City, Ca
i purchased some wiper motors off of eBay to replace my factory ones. My question is does anyone have a clue how to adjust the park? It appears that these where designed to be on the bottom of the windshield. The only way I can make it work is to put the arms down and then there first move is up. I switched polarity on the motor inside the housing and the motor goes in opposite direction but the wiper arm still goes in the same. Very frustrating. Any help or ideas would be greatly appreciated!
Post some photos of what you have. You say "motors", which indicates E-1967; those were followed by a single motor and a slave actuated by a cable. Both set-ups were at the top of the windshield(unless FJ45V/LV). They were followed by a single motor located at the bottom base of the windshield, either LH or RH side depending upon RHD or LHD. All of these were factory set-ups.
You may have something aftermarket, and a photo of your windshield frame and the motors you have will help understanding your situation.
I looked into mine. Figured out how to set the park to opposite side. (Top)
To do this you will need to pull the cover off the shaft side.
The shaft will slide out.
You will see one phillips screw holding a small retainer plate. #1 Unscrew this plate. Lift it away. Remove small gear below. #2 Once this gear is removed you can turn the main gear #3 (the one with the arm that engages the shaft) 180* which in turn rotates the cam the same 180* as the cam sits on the shaft coming from this gear.
Put it back together. Take pics along the way.
It should look like this when done...
You may need to do a couple small tweaks to get it just right.
