- Location
- United States
I can't get the wipers to work in the the new 1971 FJ40 project I am working on. Wanted to see if anyone had a good working wiper motor that I could swap out and get the wipers swishing again.
Thanks Mark, I did not. Easiest and best way to test the motor before I head your way to buy a new one? New cables still sold to replace if motor is not bad?I have plenty, but…sometimes it’s just the cable that’s frozen. Did you try disconnecting it to check if the motor itself is bad?
Just disconnect the cable mechanically from the motor and plug the motor back in.Thanks Mark, I did not. Easiest and best way to test the motor before I head your way to buy a new one? New cables still sold to replace if motor is not bad?
Motor is dead, will need a good one from you Mark. Pick me out a winner and I will call you Monday to get you $$$$Just disconnect the cable mechanically from the motor and plug the motor back in.
No new cables, but a few used ones.
HeyMotor is dead, will need a good one from you Mark. Pick me out a winner and I will call you Monday to get you $$$$
Ok. Box of motors is now here.Motor is dead, will need a good one from you Mark. Pick me out a winner and I will call you Monday to get you $$$$
