Anyone ever mess around with trying to fit a different wiper arm on minis? Seems like every time I have to change blades on my '91, I either strip the heads off the screws, strip the threads out of the arm itself , or break the screws off flush in the arms due to rusting. (If you live in CA or AZ,
It sure would be nice if there was a quick-connect style with the hook on the end that had the same splines and overall length. I've heard that most of the trucks used the same wiper arm all the way up to '04. Is that true, and did they use that two-screw design all the way through?
)It sure would be nice if there was a quick-connect style with the hook on the end that had the same splines and overall length. I've heard that most of the trucks used the same wiper arm all the way up to '04. Is that true, and did they use that two-screw design all the way through?
