Windshield wiper switch wiring
I have a 1972 fj40, took all the wiring out, installed a Kwik wire harness and fuse block. I looked in the Haynes manual, for the diagram for the windshield wipers, looked at different years trying find one that matched what is mine, had no luck, there are five wires, red with green strip, blue with red strip, blue with white strip, blue with black strip and the a blue wire, using a Kwik after market windshield wiper switch with washer, does any one know what those wires feed?
you do realize the stock switch switches the ground. 12v+ is always at the motor and you switch the ground for speeds and park.
No I didn't know that, so it sounds like I need a stock switch. So does the 12 volt power go through the switch or is it wired directly into the motor?
12- runs thru the switch, turning the switch to different functions makes a circuit because you are controlling where the ground goes to the wiper motor. low or high and I won't go into the park function.
12+ goes straight to the wiper motor.
I don't know which switch to use, I just know the switch controls the ground.
from 1975 FSM
