74 FJ 40 Windshield and seal. In Gresham Oregon or near by. Any suggestions? How much should I expect to pay? I had a cop tell me tonight that I had to get it replaced. There is a big crack that is pretty much in my flield of view. I agree that it needs replacing. Thanks in advance for any leads.
Start calling around. Any glass place that can cut and install a flat piece of saftey glass can do it. It might even be covered under your insurance...
Back in 2000 I paid just over $150 to have one cut and installed into a '74 FJ-40 windshield frame. The invoice shows that it was 19" x 53" x 1/4".
BTDT. As mentioned, a local auto glass place can cut you a new pieces of glass. If the seal is the original, I'd suggest ordering one either at your local Toyota dealer or here on MUD through C-Dan. Unfortunately, factory glass is not available for 1974 FJ40s through the dealerships, though S-O-R still had some OE glass for '74s a couple of years ago.
You can always just drop the windshield for the next week or so until you get this sorted-out. Just remember not to grin too much while driving high speeds!
The windshield is no longer avalable from Toyota for the 74 or older (they will tell you it is but the windshield that will come will be for an 75 or newer FJ40.( 1 inch wider)
Get a auto glass guy to cut it. Mine said I could get the top tint or full tint if I wanted. I got clear and it was $75 and I installed it. I got the seal from CDan and after a few hours of cursing got it in.
The seal is a 2 peice and are ordered seperatly. If you just get the seal you'll need the key to lock the glass in.
I took my windshield with new rubber and key to a glass shop and the guy worked for over an hour and could not get it in. He was trying to rope it in. I took it to another shop and the old timer had it in in less than 10 min. He did not use rope. He installed the rubber on the frame and then dropped in the glass and got it under the lip with a putty knife. He then installed the key lock with a roller. He said the key lock channels are loose enough NOT to be roped in. Charged me $20. I learned that not all glass shops know what they are doing , especially with old vehicles.
ODD, I have installed 10 maybe and all were roped in. There is a little love to doing it and it takes two guys to do it.
I placed the seal on the glass and then lubed the crap out of it with a dawn soap from a spray bottle. Placing a 1/8 nylon cord in the seal.
Placing the seal into the the bottom of the frame first and then center it. After that I start pulling the rop on each side about two inches per side working to the top. the corners are tuff and require a hard plastic tool to get the seat to roll over and not tear. then the top is easy. You will have to coach it in and pull the glass from side to sideto get it to seat.
All of mine were 78 and newer......and OE glass costs $45 from Toyota.
whats a key lock. I have a '70, When my windshield hinges snapped and the thing collapsed on me i need to get some new glass. I thought the cut the glass too small b/c the seal wasn't holding the glass is, could this be b/c of no key lock?
