Windshield install
Kenosha,WI
Using new seal and oem windshield. Looks like the pros seal outer edge in picture before install. I am worried about making a complete mess if I do that.
Has anyone applied sealant around seal and windshield frame after its installed?
If I have to apply before install what sealant has a good working life ie not 1 hour fast cure!
I just had a new windshield gasket put in today. Guys did a nice job but insisted that no sealant was used on the gasket that was removed nor did any need to be applied with the new one.
I produced the relevant FSM pages but they were unconvinced.
So the windshield is in and I’m wondering which product and how to apply it?
I would use the blue label between body and seal. You will be able to lift and get tip inbetween seal and body. Once cleaned up with mineral spirits I sealed windshield to seal with the urethane.
Thanks! I can see getting a nozzle between the body and outer seal but it’s really tight between the glass and inner seal. Best technique to get the urethane in there?
