Windshield Gasket question
Hi guys , I have been doing a week long preventive maintenance on my 80 ... I nwas replacing the " D " blub in the dash ...I notice there may have been a little water leak at one time .
I am going to roll the seal back and give it a bead of urethane just in case .
My question is the gasket on the cowl suppose to be on top of the cowl or under the cowl ...mines on top right now .
I know the whindshiel was replace .
Thanks guys
Greg
Thanks guys
Greg
I started a thread just like this awhile back. I had a new seal installed, and had to have auto glass sp. re-install because they didn't do it right the first time. And yes on top. Check the search option to read about this problem.
:beer:
top.
Bottom. It should be under the metal cowl. The expert that did mine said it is a sloppy lazy installer that puts it on top as it lets water get in under the seal as it sits on top of the metal. Putting it under the cowl prevents water from being pushed in under wind preasure. I have never seen one that was on top. JMTC, I've had three windshields replaced by two different instal co's and they both told me gasket goes under.
I am looking right at the factory Toyota manual ...I am looking right at a side view of that seal and it shows a lower water seal under the cowl as well as a upper seal that gose over the cowl ...Mine looks as it should be .
I can't see how you would get that up seal under the cowl ...There is a channel molded for the cowl to rest in ...atleast thats depicted in this factory manual .
Thanks
Greg :cheers:
I'm in a 1996 LX 450 manual No.RM482U .
The Page is BO-33 They have a whole page showing the gasket side cut away in 3 different pictures .
Greg
Does this help?
Not the same as my 94 Toyota manual. Thanks for the feedback. Mine shows cut aways but nothing with the cowl in it. :cheers:
I assume you are looking at the space just above the sealer space? My manual shows that but it also shows it all the way around the gasket not just on the bottom. When my windshield was replaced the gasket actually had an extra lip on it that went over the cowl at lease 3/4". I think the PO's previous instal actually slid the cowl under where the sealer was supposed to be. I think that's where my missunderstanding came from.
I now understand what you were talking about. See photo. This what mine looks like and I understand this is what you guys were talking about. It's all crystal clear to me now. Mine was really F'd up by the previous instaler.
Thanks for the pic Beowulf ...Side note ...thats a great gun ...LOL . Wow they really got carried away with the urethane ...
Greg
anyone know off the top of their head *about* what a toyota windshield and gasket cost?
On top.
If the windshield was replaced, it very well could have not been reinstalled properly
causing leaks or worse;
ie: no adhesive, not enough adhesive, not in the right places, no primer, etc,etc.
Cost of a Toyota OEM windshield: about $250, maybe less with a discount.
OEM Gasket: about $35. It will fit perfectly and look right.
I highly recommend staying with OEM glass; everyone (at least the installers) will tell you
"glass is glass, it is all the same" NOT.
Had mine done with ?LPG; pos; like looking through the wrong eyeglass prescription.
Had it redone when it leaked (they used NO adhesive/sealant), and this time I demanded
OEM Toyota; immediate improvement.
One word of caution; go with the installer that has done all the local work for Toyota, Mercedes,etc;
for years; they do not keep using an installer if they do bad work.
I do not recommend any of the National chains (Safelite,etc)
G
I just had my windshield replaced and took the book with me to show that the gasket gets glued to both the glass and the body. I noticed that the Lexus manual referenced shows only the gasket getting glued to the body. The cross section of the gasket also looks quite different. I wonder if the gasket is a different part number 95 & up? Maybe due to air bags?
Dave
Maybe some board members who purchased their rigs new can chime in here. I'm wondering whether the wind noise that so many members have noted is caused at least in part by improperly installed windshield gaskets. I just checked mine. It is on top of the cowl, and I have what I think is excessive wind noise.
The correct answer is both. The gasket has a lip in it that the cowl slips into, however the urethane should be applied on the seal under the cowl. The part of the gasket on top of the cowl is more or less cosmetic.
The gasket is if I recall correctly about $60. The glass a bit more.
My 1996 had the original windshield; only noise was from
the mirrors, etc;
If your door seals/rubbers are worn, or the doors themselves are
out of alignment, loose, bent etc, then you will get more road noise.
Get inside your vehicle and have someone push on the DS door/window frame from the outside while you watch the window frame;
some flex is normal, but if it appears too much, your door may
not be fit properly, either from the factory, or from some
Gorilla who swung on your door.
I took a long tour of a autoplant once (ergonomic course I was in);
I was amazed at how they straighten the door window frames;
they take large rubber mallets and beat on them until they line up!!
On the other hand, an improperly installed windshield can whistle,etc.
You could get a stethoscope and run it by the windshield gasket, the door/window frames,etc while you go down the road to try to localize the noise. Maybe have someone else do it if you are driving;)
g
