windshield creaking
Yuma, Az
yesterday I noticed while driving to work when I was on a rough section of street there was a creaking sound but couldn't locate it. today I heard it again and decided to push on the inside of the top part of the windshield. the same creak was a result. only on the top, not the bottom. what could cause this? time to remove and replace the seal? anyone else get it?
i just got back from the sierras and the snow and now it has it. I also developed a leak that came out above the ps, from under the dash. I cleaned out the sunroof drains and went away but now it has me wondering if the windshield seal is bad...
Your windshield seal is likely bad and causing the windshield to move around. I had the same issue and had it re-sealed, got a new liner from cruiseroutfiiters. The 80 needs sealing on both side (inside and outside) which most installers are not aware of. I had to get my installer redo mine, and even then it was only injecting a lot of sealant from the outside (removing the windshield will likely mess up the rubber liners). Fortunately that has held up, and i get no more creaking.
Well known issue: the windshield glass must be removed and resealed using the correct urethane Adhesive-Sealant, while following the procedure in the FSM. Fix any rust while the glass is out. As mentioned, many installers skip the Adhesive-Sealant or don't apply it correctly resulting in creaks and leaks.
THAT specific product has been NLA for years.
