window rail install links or tips?
tejas
anyone got a link or tips on window rail install? i’d like to get in and get out and i am hearing conflicting info on whether i even need to pull the door card, or to roll the window down, then up (?) or whatever.
i know there is a specific rail for each window. but not sure if there is a correct place to start the install (like in a corner) or what exactly.
THANKS for any help.
pic of the pulled down card is from a video on pulling door cards and/or replacing door lock actuators.
Yes pull the glass out and clean the edges, with window cleaner, now use soapy water to slide the rubber in the groove, also lube the regulator and small wheel's with a quality grease , if you want to be lazy just pull door card , roll window down half way and lube the rubber and slide it in
thanks shocktower. i have to admit this will probably seem simpler once i open it up.
are you indicating that a full r&r involves removing the actual window from the assembly, installing the rails (and greasing components) - then putting the window back in the assembly and basically rolling it up?
Once you take the door card off everything becomes easier. also for a faster window make sure that your pieces are street and not bent. I’ve found several that are slightly bent and even after lots of new parts it still is difficult to roll down quickly. Fwiw.
I do pull the windows, to make sure they are clean, remember it is a 22+ year old dirty crack, that probably never been
