Very cool build. I've always wanted a hidden winch, or at the very least one that shows the fairlead only. I'll be in the market for a winch that will fit in the months to come. I have welders/tools to handle most of the work, but might have a local shop help w/ the fab work to make sure it's strong enough. Your pics will give me a good starting point!
Random quesion, but if you were to anchor the rear hitch to a tree to keep your rig from sliding...would there be a concern with causing frame damage? Or is your set up and frame strong enough? How about with a snatch block?
I would hope I never need to anchor my 3 ton vehicle, but for a badly stuck friend coupled with 18k lbs of pulling power, I wonder what would give first??
The rear hitch will hold up pretty much as long as the pulling force is applied gently, avoid shock load on the hitch (snatch strap/rope). For a simple anchoring i would not mind using the hitch, but For a very hard pull with a block, i would (whenever possible) use frame recovery points for anchoring, preferably both sides in a long "Y".
For snatch straps/ropes, always use the frame recovery points (not the "tie down" points or hitch).
For all recovery operations, think three times over what you are doing, it will often involve great forces, winch cables and towballs flying around aint as cool as it sounds
Equiment in good quality and condition is often a mayor factor of success, wll/swl ratet lifting equipment is great for recovery use, as its breaking strenght is many times the ratet capacity (and the rated capacities can be trusted)
I recomend carrying the following minimum of equipment if there is a chance for offroad recovery:
- At least 4 rated shackles, wll from 3-5 metric tons.
- Winch extension line, about 30m will be fine, depending on terrain.
- Winch anchor, for very open terrain (where there are no trees).
- Tree strap (short, wide lifting strap). wll from 3t.
- Snatch strap, rated at least 10t breaking strenght for the 100.
- Snatch block.
- 5-10m wll 3t lifting straps, has many uses.
- Shovel.
- Axe.
- Spray can with starter gas and lighter for rebeading tires.
