This is a question for any electrical gurus, guys who have trouble-shooted their own winch motors, or anybody who knows the basics about electrical motors such as the motor on a Warn Upright (Belleview, 5687):
I've talked to a couple of guys at Warn and also the midwest 4WD place that sells old winch parts, but their kind of hard to get a hold of; my winch motor won't spin, and I've checked and re-checked everything I can think of.
Doing some continuity checks inside the motor: The big power lead excites (2) of the magnets inside the case, and these magnets are connected to (2) brushes. Everything checks out continuous and nice.
The OTHER (2) brushes are connected to the (2) OTHER magnets on the inside of the case. Again, good continuity, everything is clean and nice.
So if these second brushes get power from the armature, which gets power from the first set, then basically the power that comes in from the battery has a direct path to the motor case, is that correct?
That's what my testing shows. Am I measuring a dead short, or is this arrangement correct? Since the armature is also the shaft, and is supported in the winch case at the bearing in the case, seems to me a direct path to ground from the post on the motor to the winch case...
Again, am I measuring a dead short, or is everything as it should be?
Ned
