I am trying to install Slee's in-cabin contol for the winch using the up-down antenna switch.
I worked on it until 1am and at the end it is not working. I need help troubleshooting to isolate the problem.
Ran 5 wires from winch control to inside. All wires on the Warn control side (outside) were terminted with an eyelet and soldered.
Red to Red
Brown to Brown (inside leg of the selonoid)
White to White
Green to Green
Black together with the Warn black to ground.
Here are the tests I have done with a voltmeter:
Red and Black in-cabin end -> I get 12V
Brown, Green, and white and ground -> 0 volt.
Red and one side of the antenna switch wire 0 volt, pushing UP button -> 12V (as it should)
Red and other side of the antenna switch - 0 volt
pushing the DOWN button -> 12V (as it should)
So I know the switch is working as it should. Providing ground when pushing either UP or DOWN.
I need to know how to test the white, brown and green wires.
My thought at the moment is to connect the Warn remote control and while pushing OUT - and if the wires are good - I should get voltage on white, or brown, or green.
Alternativly I can jump the in-cabin wires. In that case what wires should I be jumping. I am assuming it starts with the red (which I have 12V on).
This will isolate the problem to either the wire or the Slee module.
TIA
Rami
Red to Red
White to White
Green to Green
TIA
Rami
