Thanks for the advice.
Here is more info. The carb does appear to be getting fuel, the float is in the middle of the window. As for timing, I think I did it correctly but am not sure. I tried to put the new distributor in the same way as the one I pulled out. When it did not fire, I decided to try to get the motor to TDC following the manuel. I got the timing mark to show in the window, put the distributor in like in the picture in the book and placed the rotor facing toward #1 plug wire. No luck. I tried several times, adjusting the distributor back and forth, but no fire. I will try to see if the ignitor is not working, but it was working before I replaced everything.
I am not sure of the oil pressure. Should I have it if it is not running? I was not sure if I had gotten the distributor in the motor far enough, but tried several times to get it in as far as it would go to engage. How can I be sure?
Ken, I am reading your thread and wondered why a remote starter? Can I just have someone turn the engine over with the key and feel for the air in plug #1? When you suggest using a prybar to turn the engine, do you mean through the timeing window? I will also try the timing light trick to check for spark.
