Will no front panhard correction make it pull left?
You want to make sure that all contact points for the shoes are clean and greased with white lithium.
A possible problem is that the shoes "rock" in place when you apply the brakes. This rocking can simulate the e-brake action and cause them to over adjust and bind.
The system is designed to adjust the shoes when you use the e-brake. So I assemble the shoes with drum and then use the bellcrank like a ratchet and repeatedly move it until the clicking inside the drum stops.
Would a slight "knock" as I take off from a stop be indicative of this happening? Because for the longest time i have noticed a slight knock occur in the drive train as i take off from a good stop (not a rolling like i mostly do).
i pulled the drums off earlier and there is no broken spring. lots of dries mud that has made everthing kinda..sticky? should i take a pic?
