SOLD WI - Very Nice Front Knuckle Balls - 40% Price Drop
Status
Not open for further replies.
Drake2
SW Utah
Are your balls suffering from years of abuse by too much pounding? Have you not taken your GF/Wife or both for a ride due to your current ball neglect and inability to perform without leaking? Do you dream of replacing your balls with ones that will provide you with many more years of satisfaction? Say no more, dreams do come true.
Clean units here, only one little ding at the very end of turn travel. Grind the factory weld pop out the balls and weld onto your axle.
$150 shipped for the pair.
More
Just curious but what were and what could these be used for?
Hi, many times the machined surface of the balls are pitted deep from rust. Once pitted, the wiper seal can't wipe clean as you turn so it can drip grease and oil. The pits can also wear out the rubber seal prematurely from the rough surface. I have never seen the balls come up for sale and shipping the whole housing can be expensive. The ball and tube are pressed into the housing and welded from the factory so grinding the weld allows you to remove and replace the ball without replacing the whole housing. If that is being done on a SOA rig it's a perfect time to do the "cut & turn" operation to correct the steering geometry.
Those 3 position shock mounts were a disaster added by a PO of the rig that the axle was under
Ball bump
bump
40% price drop
Status
