Why?? Surging in low Gear
Gentle surging can be caused by a slightly too lean mixture at the mixture screw. Usually noticeable when cruising (even throttle application) at moderate engine speeds.
Larger levels of surging could be due to fuel starvation - check float levels, dirt in float bowl. Or the opposite - if associated with black smoke - could be too rich, which might be related to float level, mal-adjusted accelerator pump etc...
It it doesn't seem to be fuel related, then check your cap and rotor etc...
