Why change diff fluid after water crossing ?
Burbank, CA
Hey Guys,
Ive read in many posts that you have to change out the diff fluid after a water crossing.
Aren't the diffs waterproof ? I will be putting my 3rds back in today, and Im going to use grey RTV instead of the cork gasket. Wont this make it waterproof ?
I am also going to extend the breathers up into the engine bay.
On another note, how much RTZ should i apply, 1-2 mm bead is ok ? Im thinking of going inside of the bolts, that should be fine right ?
Harry
It's not an absolute given that you need to change the diff fluid after a water crossing but you should at least check it for contamination.
If you have been running for a while you should let things cool down before you attempt any deepish crossing. The reason being that the hot axle/diff housing being rapily cooled in cold water will cause water to be sucked in past the axle seals.
What we normally do is when we get to our first river crossing on a trip, stop and perform step #6 :beer: a couple of times then continue on.
Extending breathers is a good idea.
I think you're about right with the RTV
I used rtv on mine when I did the diffs and just ran a thin bead around each bolt hole.
let it set up for a bit (a minute or three) before you assemble and it won't ooze around quite as much.
regardless, it is worth checking the diffs after serious water crossings to see if the oil has gotten wet (it'll be cloudy). If it does get wet/milky, change it. Otherwise, just run it till your regular change interval ("heavy" use is 7,000miles, I think?)
I change mine at least once/year and probably more often due to water.
Everybody else has already said everything useful.:crybaby:
I always use my finger to smear the RTV, and dab it, so it gets better adhesion. Apply it to both surfaces in this way and you'll be good. Or do it your way, and also be just fine.
why not just extend your breather lines? mine go up to the top of the snorkel
in 2 years of ownership and literally hundreds of deep water experiences (often up to and over the bonnet) i have never found water in the diff oil or swivels.
I personally think this is an overexagerated reccomendation. I would say you should change it at the regular maintenance intervals. Use common sense, if you were on a trail all weekend driving up and down rivers up to your doors, you should check all your fluids, a small river crossing is probably not a big deal.
Noah
