WHOOPs -- Got Engine Wet
Call me a dummy! I just learned a valuable lesson on the 80 series -- to take everything "OFF" and clean it separately. Lots of electrical stuff on the newer models.
On the 93 I wanted to "clean" up the engine compartment. I "bagged" the distributor and wires and used some engine bright by GUNK. I let it set and then used water -- not a hard spray but the "shower" function on the hose sprayer to remove the GUNK.
Started and it was running rough -- drove it and it continued to run rough like it was"missing." Got a couple of miles and "check engine light" came on. Turned off engine to reset and roughness was replaced by different issue at higher RPM - it wanted to cut out at about 2000 rpm --- soooo, limped it home at 10 mph. Oil pressure good, temp good.
I put it in the garage and opened the hood to dry it out with a box fan. Took off Air Meter connection and water ran out on the wire side of the connection. Hopefully that is the problem.
While it drys out, am giving it a tune up. Plug gap of used plugs is about 0.052 - not much electrode left -- need distributor and rotor too.
Have not got to the #6 plug but the other have a "little" oil on them. Is there a valve cover gasket seal on the head that periodilcally needs replacing? Plugs are a white/brown so burning OK but a little oil on the threads and at bottom of sleeve.
Anything else I can do before I start it up again?
...bettin' your main trouble was the distributor. No matter what I've ever done to protect the diz, it always gets water in at least one of the three holes in the housing. Be prepared to unbolt it and dry it out with a rag each time you rinse the engine, drive through water, etc. and you'll be fine.
Good time for a tunin' though. Good luck.
Dan.
You shouldn't have driven it if it was running rough to begin with, that could have caused other problems. Likely not but possible so you should be ok.
I always cover the distributor and the MAF sensor wiring when hosing down the engine
If your valve cover is leaking, that would be a seperate problem and yes you can replace the gasket, but you should replace the sparkplug gommets while your at it.
Is there water in the wir can? Take off the hose and check the throttle body to see if there is water there. If there is, thats worthy of another post.
Thanks guys --
Will give tune up and try again -- before I do, will dry out distributor.
Romer -- what is the wir can --- This is a rig I have had for 2 months so am not familiar with all the electrical componants and fuel injection --- I have a 75 Pig and 72 FJ40 which are carb rigs.
Thanks
typo - meant air can. The thing the round air filter is in.
Don't just loosen the wingnut and take the top off. You need to take the clamps off at the air tube. A common problem is to break the hard plastic tube.
Already took it completely off to clean it up. No water in the Air Can --- Completely dry - inside was relatively clean. The little secondary can was about half full of dirt so disposed of the material. Cool system for collection of dirt.
Also -- I assume the MAF sensor is for the air flow meter connection? Noticed there was an epoxy seal on the top connecting the black plastic to the aluminum meter --- anyway water could get inside --- epoxy seal looks tight -- Like I said above, quite a bit of water came out of the harness connection -- wire side - not air meter side.
Thanks again for the help!
Water will get into the harnesses that have the grey plastic tube over them; just got to pour the water out before you hook the battery back up (I always disconnect it before I wash my rig), or be careful not to spray toward them. All the above comments, plus, if your rig has the original ignition wires you might want to replace those, the seals where wires go into the connectors/boots leak when they are old, so water gets in easier. A new distro cap, rotor and plugs will help I'm sure. The main thing when washing the engine is to know what you are pointing the water at, and avoid as much as possible electrical components, harnesses, dipsticks, brake reservior, disto (all covered) etc IMO.
ordered new distributor cap, wires, belts, PCV, grommet, rotor, from Cruiser Dan today. The #5 and #6 plugs had water in the wires and around the plug --- dried it out and put new plugs in.
Thanks
