Whomp whomp noise
Northern New Mexico
I've been trying to diagnose a "whomp-whomp" noise that starts at around 15 mph and increases in pitch up to highway speed. I know these kinds of threads are difficult but I'm hoping to gain some insight so I can continue to evaluate this issue. Here's some info:
  • I did the front axle rebuild with new bearings all around, followed FSM specs for torque etc., about 5k miles ago. The noise started approximately 2k miles after the rebuild.
  • I most likely over-filled the knuckles as the driver side spit out a glob of grease past the wiper every now and then. Since the over-filling they're more like 7/8 full now.
  • I bought new tires: 33" DuraTracs. The tire shop said they had a hell of a time balancing them. The noise started about 1k miles after I put these tires on, I asked the tire shop to do a road force balance and they did. No effect on the noise.
  • I checked the front bearings for play by wiggling all around. No play.
Any ideas here? My suspicion is that I have an out-of-round tire, or some other tire problem. The noise doesn't get any worse when I turn side to side from what I can tell. Also, now that I'm thinking about it, I replaced all tie rods and ends and never got the front end alignment done afterward. Could that be the culprit? Any help would be appreciated. If these tires are just going to be this noisy I can deal with it. I just want to make sure my truck drives safely.
You should get an alignment after replacing the TREs.
Did you grease the brass bushings on the spindles? Stock rims? Wheel spacers? My guess would be the tires. Can you swap them with another set and see it your problem goes away?
Whomp whomp noises are usually tires.
That being said, you need to get the alignment checked to make sure you're not wearing the tires poorly. You should also rotate them. That alone may cure the noise.
If your knuckle is puking grease, you need to clean your axle vent too.
I made sure to grease the spindle bushing after reading about it here. Sounds like I'm due for an alignment for sure. And I'll check the diff vent. I rotated all 5 tires 100 miles ago with no change.
I've heard these heavy tires can be a bear to balance. I wish I had kept my LTXs to test the noise.
^^^^^ Agreed, almost certainly tire related.
