I'd expect an engine like that to be running above 20psi boost in standard trim. How else do you think they get torque figures that high?
Still, the aftermarket will be interesting.
If the comrpesion still 18.6:1 ( that's the same as 1HD-T and FT ) I thought they are not running more than 12 PSI .. and pointing to the engine longevity ..
As same as you can see in ZD30 from Nissan .. of 1KD-FTV .. with a hack in the signal the factory ECU still working as same .. but all signals that the ECU generate to the Turbo ECU are " altered " in order to make more boost soon ..
Actually you can buy a cheap " chip " for 1KD-FTV ( that I see here in Panamá ) in about 600 USD or so .. and get 20% - 30% better performance just going from 10 PSI to 14 PSI ..
Could the 1VD-FTV go far away over 18 PSI . ?
