white smoke coming from tailpipe
Sacramento
My 96 cruiser has been running rough lately... It now has smoke coming from the tailpipe...(it is not due to cold weather) I have been loosing coolant and it has been having a very low rough idle occasionally when I stop. On top of all of this sometimes when I go to start it it won't turn over..it like clicks or does nothing. Yesterday when I went to start it it didn't turn over but there was a loud clank near the engine...and it seemed like something seized up. Please help..I am so lost. Thanks
the bad news is:
sounds like your headgasket failed- coolant entered the block and you spun a bearing or broke a rod
or:
you have a coolant swilling rat that has eaten a hose- is drinking your coolant- and when he senses you turn the ignition switch has a large ball peen hammer he is pounding on your engine block to scare you into believing the above bad news has actually happened.
solution: check for a coolant-drunk rat with large ball peen hammer in tow.....
check under your oil fill cap for brown goopy goo.....
If you dont see a rat- and see some light brown goo- id vote for a blown headgasket.
the bad news is:
or:
Even though I don't like rats I think I would prefer to find a drunken one under the hood....
Thanks for the input, I guess I have a blown head gasket. :( Now I need to investigate and pay to have it fixed..what a bummer! But I love my rig!!
if lower end is damaged - theres a bunch of toyota specific dismantlers and you can probably pick up an engine on the cheap in sacto.
although: you may end up with a parts rig that may be worth selling for parts and just scouping up another one with no issues for about same cost as repairs$+parts rig$
if its just a headgasket then its fix n go
Sorry to hear about your motor.I also had white smoke but recognized the signs in time and didn't damage anything in the motor.Took my time doing the rebuild and doing it with birfmarks fsm found here on mud.also while your in there disease hit my wallet pretty hard.but very satisfying to hear it run.doing it yourself you can learn so much about the truck.
Thanks for the advice.
I hope I caught it in time. I'm optimistic, its only been a few days with the smoke coming out of the tailpipe. However the coolant and rough/low idle have been happening for a little while. :(
I checked under the oil cap like bugsnbikes suggested yesterday, and what do you know there is nasty brown goo.
Okay. You need to do something before you post anything else. That is to remove the spark plugs from their holes and remove the wire from the ignition coil or unplug the coil. Have someone turn the engine over and look to see if there is a rush of coolant coming from the spark plug tubes. I say this because a clank noise doesn't necessarily mean anything unless you had a bunch of fluid in the cylinders last time you tried to turn it over. If there was fluid in a cylinder you have bad connecting rods now if not a hole in your block. If not then the sound could have been the starter, might be related to your starting issue, but I'm going to say that a hydrolocked engine was most likely the starting issue. Which leads me to ask, why, if you were so sure you had a blown head gasket were you driving the damn thing? Easy cheaper fix is to repair the head gasket at first sign of problems more expensive way is to force a failing engine to completely s*** the bed before asking advice. Sorry for the crass comment. It just sounds like you had a fairly good idea of what was going on and possibly pushed it too far.
Thanks for your advice. I will remove the spark plugs and see if anything happens.
No need to apologize. :) I didn't know it had a blown head gasket. I thought maybe the starter was going bad. However someone told me they didn't think it was the starter but probably the ignition switch. Since that's what started first. Then the coolant started leaking, so then I drove it sparingly..(like to get the kids to and from school..) Then the rough/low idle started, but it never over heated. I parked it for a few days then went to start it and bam white smoke coming from the tailpipe. So it has been parked ever since.
'Don't panic yet! I have seen dozens of hydra locked diesels and pretty much all were toast but, gasoline engines often get away with it, more so as the starters tend to be lower in power, i.e. 2kw or less?
Pull the head, then before you spend a penny have a MECHANIC (not your neighbours best mate who might have a 'lookatit fer ya'), measure the stroke of each of the SIX pistons, compare them, a bent rod will stand out like a sore thumb, next look at all the bores for scoring, again a bent rod will jam the piston crown or skirt on one side of the bore leaving plenty of evidence of damage, if good then look at the wear ridge at the top of the cylinders, it should not be too prominent, again a MECHANIC will put you right on this. If all checks out then get the head crack tested, valve job, skimmed and put back together with OEM gaskets and you should be good to go.
A little story for you:
A friend had took his neighbour to the airport in her car, on the way back the check engine light came up and the car run like bag of nails, losing power and cutting out, black smoke the whole nine yards. Chugged back home the local 'I will lookit it fer yer' mechanic plugged his SUPER DUPER SPECIAL COMPUTER and declared the turbo and air mass meter were toast, he could fix it all in three days and it would only cost 'around' 2,500 euros ($2,700)! I was called in to see if I could fix it cheaper, I turned up and plugged my machine in and sure enough it gave up the codes for air mass and low turbo pressure. So, after taking the time to remove the air cleaner (4 clips and as many seconds) I found a rat nesting in the air box, the pair of gardening gloves (owner lost them a couple of weeks back), the chewed up air filter all had got sucked into the air intake and fouled the air mass sensor, and of course no air - no turbo boost out, took photo's!!
A new air filter, bit of scrap metal mesh over the air intake to keep our furry friend out, reset the OBD and the car is still running perfectly today 3 years on!
A bit weird that today I actually serviced this same car and this thread turns up.....hmmmm twilight zone..........
NEVER assume the worse case scenario....period!
regards
Dave
Being in Sacto, contact @orangefj45 Georg has a shop in Stockton- Valley Hybrids. Excellent mudder and mechanic. And knows cruisers inside and out.
