White Roof Wrap
I had the roof wrapped in 3M 1080 Gloss White by a local shop.
I think it turned out well, or at least as good as it can for lines that end in free space on the body.
Subtle throw back to the original. I dig it
It does look like the transport film. I can dig it.
will you be putting "54" on the roof? .. Just kidding .. Like the retro look, Likely keep it cooler in the sun also.
If you live in an area that is prone to extreme heat and sun, look into "bus-kote"
It is a polymer paint with ceramic beads that reduce conducted heat.
I reduced the internal temp of my truck almost 15 degrees and the rear AC cools much faster, since the ducts that run along the roof don't get as hot.
It has held up great for over a year.
50$ a gallon on amazon. Took less than half gallon for 2 coats on my roof.
I rolled it. It came out like rhino lining. Kinda orange peel texture.
Stuff likes to be applied in cool temps. I was starting at 6 am in arizona. It got warm outside and I rushed to get it on. Probably could have sanded between coats for a smoother texture.
Looks good, just don't pull me over!
