Whistling carb
Orlando, Fl
my carb is whistling, so i took it off the manifold, but theres that black plastic thats still there. should i try to pry it apart? i have this this gasket making stuff for oil pans and engine heads, should i try to use it. if i do, how long should i let it sit.
Maybe not the carb doing the whistling. Might be that pesky vacuum leak...
would that make sense if it didnt whistle when it was cold, when it warmed up it did.
If it whistles while you're driving then I guess you could say it "whisltes while it works" Seven Dwarfs......Get it?
Yup. Torque your manifold stud nuts down.
probably an air leak and yea you should probably replace the gaskets ans seals or whatever?
replacing vacuum lines is easy also. just get a diagram from spector and go to work.
Sounds like you are talking about the carb base insulator that has the carb base gaskets attached to it from the factory....
I would just make a couple new gaskets from general gasket paper available at better auto parts stores...
After you get the carb back on, spray carb cleaner around the manifold and see where you have a leak....if you spray the cleaner at the base of the carb and along the intake manifold when the engine is idleing, and the engine RPM's increase, wherever you just sprayed the cleaner is where you have a vacuum leak...
Sounds like you and Newrider both have your hands full of poor running Land Cruisers....
Good luck!
-Steve
one guy mentioned to me that it could be a little gap on one of the butterfly valves. is this a possibility? and where would i get a new one?
SandRider
Just went thru a simmilar problem to many a members dissmay.
It was suggested that i should try to wiggle my carb. Sure enough the base plate was a little loose causing it to wiggle. After remooving and replacing carb, both plates, and both seals. She was whistle free.
Absolutly replace the gaskets and use a non-hadening/non-silicone gasket seal.
It only takes 30-40 mins.(with a beer). Plus it is cheap insurance.
Good Luck
Whistle at idle and goes away when you floor it: = Vacuum leak on intake side of manifold.
Quiet at idle and noise increases when you floor it: = Exhaust leak.
Quiet at idle and noise increases with engine speed (but not load): Air leak above the throttle plate and below the air cleaner.
