While we're there replacing Head Gasket
Seattle, WA
Need experienced eyes to look over this list and help me decide what really ought to be done, what's overkill, and what I've overlooked on my '96 with 151K.
Head- valve job, valve stem seals, check all head bolts
Distributor- o-ring, cap, rotor
PHH- silicone or green stripe?
Plugs, wires
Alternator brushes
Oil pump- gasket, seal (are those 2 different items?)
Crankshaft seal
Oil cooler- remove, desludge
Oil pans- pull and clean
All hoses
Timing chain, guides, tensioner
EGR gasket
o-rings- dipstick, tranny fill-tube
water pump
fuel filter
Blue hub clutch
I would definitely have the fuel injectors cleaned. Might as well clean the throttle body as well.
You stated "all hoses", so I will take that to mean all the vacuum hoses and water hoses under the intake manifold.
I would consider replacing, or at least closely inspecting all the hidden goodies under the intake (VSV, for eaxample).
Since my rear heater tubes are basically shot, I would replace them if the head was off (although I'm not certain it can be done with only the head off).
Probably a good time to replace the starter contacts if it hasn't been done already.
A good list so far, I'd add the following:
- oil pump cover gasket and O ring. Yup, two diff items. Order extra bolts in case you ruin them.
- pull the radiator out and wash/clean the fins. Maybe professional rodding?
- wash the A/C condenser from both sides (easy when the radiator is gone)
- head - shave so that it's truly level
- decarbonize the tops of pistons.
- clean the intake clamshell. You can have the engine shop toss them in their clean tank.
- clean the valve cover. " " " " "
- protect the ECU harness by the EGR tube
- check and clean ECU relay (driver fender)
- check and clean the charcoal canister
- replace the VSV for the dreaded P401?
- clean all vacuum ports inside the intake; particularly the large EGR PORT in the
- replace the PS hoses (high and low press)
- check for trueness of the engine block surface. If you see surface pitting from corrosion, you've got a large issue to contend with.
- send the injectors out for R/R. I used mail order and saved ton of $$ ($13/each vs $25/ea locally)
- Tstat and gasket
- if you live in an emission free location, delete EGR system? Just a thought.
- PCV air/oil filter or a PCV catch can to keep your intake clean and beautiful?
- give the block and heater core an "enema" by reverse flushing the system through the water pump port. Flush and flush often through both heater cores.
That's all for the moment...
how big is your wallet and is this vehicle your DD?
You are welcome to do something like this.....
https://forum.ih8mud.com/80-series-tech/184022-rust-belt-rebuild.html
(This work was done over about 6 months, slowly, as I had money and as the parts rolled in. Lots of these parts were not even in the catalog and had to be added).
EDIT: looks like the pics have not been migrated.
I concur on the injector cleaning and the entire intake system. All hoses under the manifold.
This may take things to a whole new level, but since you asked, and since you're thinking about taking off the pans: It's not much further to change the rings and rod bearings. I would do it, if you're keeping the rig for a long long time. Also a quick hone cleanup while you've got things apart. Allows for a good inspection of pistons and wristpins, cleaning up the lands, etc. There have been a few reports recently of these engines developing rod knocks, so the bottom ends are not as bulletproof as many people think. Freshening up the bearings will add lots of miles.
I'm not sure if this engine has oil coolers (small nozzles) in the oil sump area that spray oil (for cooling) onto the pistons? If it does, while you're in there, remove and/or clean them out.
Also, there have been reports of some serious rust gunk built up inside the water jacket, especially around cylinder #6. I'd probe that whole area back there with a coat hanger and fashion some kind of small diameter pipe that you can squirt high pressure water back there with, down inside the jacket to clean it all out. In fact, I think this procedure should be part of any HG job, since the excess heat at #6 contributes to the HG failure. Better flow = better cooling, never a bad thing.
While you've got things apart, clean and carefully inspect the block area around the freezeplugs. There have been several cases of stress cracks developing in the block around these areas.
There are some pics that may help you with this project:
https://forum.ih8mud.com/nm-high-de...diesel-freak-anti-1fzfe-freak-same-place.html
Here are some pics of the cylinder nozzle squirters as mentioned above:
https://forum.ih8mud.com/nm-high-de...-anti-1fzfe-freak-same-place.html#post4127900
Truthfully, I suggest to people that if they're thinking of doing a head gasket project due to age, failure, PM, etc, that they just pull the whole engine out. It's much easier on the back and you have serious access to everything, including the rear main seal and the oil pan arch sealing surfaces. Anyway, this isn't the route the OP is going but if he is so inclined, he can still pull the block out (I did) and do everything outside the engine bay. It'll be much easier to pull the block out by itself rather than the whole engine.
Anyway, let me know if you have any questions.
Cheers.
