WAVEPIMP said:
I saw a post on here, that if you have a fj60 that was built august of 85 or newer, then the h55f would bolt right in, but if you had a pre august 85 one, then you had to do some more stuff to make it work. I have a 85 fj60, and how do I find out if it was built before or after august of 85? Also where do you guys get the h55f tranny? Just curious, because i may do this in the near future.
Thanks James
The cut off is October 84. You will be fine. The things that are different are easy to change out. Here is a list of things that are different with a pre 85 FJ60:
Driveshafts: Any drive line shop can make them longer and shorter for small $.
Transfer to tranny bolts-you need the longer ones-buy new from Toyota.
Shifter for transmission-but an earlier one will work with the bushing from Cruiserparts.net. I reccomend new.
Transfercase linkage-Bad news-you need the whole thing from an 85 or later FJ60. pre 85 linkages will not work, don't go there. It is also available new from Toyota.
That's it though. Approx costs: Driveshaft changes $150, Bolts $50, Shifter $100, 5 speed knob $30, Transfer linkage $150 or so (mine was free
There are other minor differences between the 83-84 and 85-87 trucks but they are not changed or swapped with the conversion. A partial list:
Rear motor mount(Not interchangable)
Crossmember(Holds the rear motor mount so year specific)
Shifter boots
Clutch slave cylinder-Actually the pre '85 is preferrable as it is adjustable
Skid plate-the oil drainage holes no longer line up-a minor annoyance.
Transfer case drive flanges-use the ones specific to your year-they were different 83, 84, and 85 up has a bigger bolt pattern. They all fit on the output shafts so you need to use one with the right bolt pattern for your driveshafts.
I would have a slight preference for the 4/86-87 transfer case as it has the larger idler shaft. In my case, I used an 87 transfer case with 83 output flanges to fit my driveshafts. (83 and 84 flanges have the same bolt pattern, even though they are physically different parts.)
