Which rear locker
Upstate NY
I did a search but didn't find the thread that must be out there.
What is the best choice for an aftermarket automatic rear locker ie Detroit, Powertrax, Lock Rite? Not looking for air locker. thinking best bang-for-the-buck, but nothing with questionable reliability.
I'm sure this must have been addressed (many times) just couldn't find it.
Thanks, Ken
Search Keyword: Aussie, Detroit, Etc, Etc. I heard Etc makes excellent ones ;)
Tons of articles on the subject. I Have an Aussie and so far so good.
x2 on the Aussie
I had a lockrite in my old 60 and it would fine too, but the Aussie has been alot quieter in turning.
slight hijack... does anyone daily drive with an aussie or detroit?
thanks,
To me, having a center diff, and consequently two more... would mean that all 4 wheels get equal power... And therefore would make unlocking a pocket locker harder in a turn...
"Unlike some other types of lockers, the "Aussie Locker" has a locking and unlocking principal that is dynamic. Dynamic in that the more power that is applied, the harder it locks so it doesn't need large bias forces operating on it to keep it locked. "
:confused:
Whatever floats your boat, but I'd go selectable's.
However, IF I had to choose a pocket locker. I would choose the Aussie b/c of this statement:
"The"Aussie Locker" has approximately 1/2 the backlash of some other automatic lockers. The design use specialized low profile gear sets (small, wide teeth) which have almost zero backlash when engaged resulting in smoother operation. Any backlash present in the locker occurs between the cross shaft acting in the grove cut in the cam gear. Because the camming operation is smooth and progressive, rather than sharp and abrupt, it results in well mannered handling characteristics over other automatic lockers."
I also think that driving a vehicle with a spool in the rear, especially a heavy vehicle, would make it less noticeable. I also do not think a lot of ppl here could differentiate the difference in a rear pocket locker in a turn, and a rear spool in the same turn.
Flame suit on :rolleyes:
I have an aussie and love it. Can't speak for the others.
have an aussie locker and my 80 is used for daily commute. no problem.
All those with Aussie's: did you check the tolerances during/after the install and did you have to shim anything to adjust it into spec? I just want to be prepared for when I go to put one in mine...
Thanks!
Thanks!
Here is Hayes' writeup (Featured on aussielocker.com):
Aussie Locker Install
Here is the result of following Hayes' thread:
https://forum.ih8mud.com/80-series-...93-fzj80.html?highlight=aussie+locker+install
https://forum.ih8mud.com/showthread.php?t=118690&highlight=aussie+locker
I have a lock rite and DD to work and everywhere else no problems.
Aussie or lock rite are a good bet.
It is almost like these rigs where made for them.
I never know it is there unless I am in a parking lot and the window is down and I make a tight turn I can here it ratchit sometimes.
Otherwise it has been great and increases your off road capability alot!
For the budget an Aussie can't be beat..... i'd still go ARB though:D
Thanks!
I did check per the instructions and everything was in check. I didn't have to do anything extra.
I called the tech guy at Aussie when I was installing one in my old 60 (given it is a bit different in that it's semi float and utilizes c-clips) He said build it as tight as you can, you can't build it too tight because the tightest it will go together will still yield a gap inside the low side of tolerences.
The Aussie is good. I've also had good luck with the Powertrax. It's quieter and smoother than the Lock Rite. Lock Rite and Detroit are both reliable but not as DD friendly as they ratchet a little harsher. Auburn also makes an electronic locker you might want to look into.
Good thread. I'm thinking about throwing in an autolocker as well. I think I'm decided on an Aussie too. What kind of longevity should one expect from an Aussie or any other autolocker? I had a guy tell me to expect autolockers to only last about 3 years before the teeth wear down and they don't lock up. Any truth to this claim?
Have had a lockright in my samurai for 10+ years (w/ hard use). Its a little worn but still works great.
I'll be doing an Aussie in my FZJ...
