- Thread starter
- #21
Thanks for the info. I've been looking into solar panels for a while now -- originally for another purpose, but I'm seriously considering it for my trailer. I need to get more active and read more in the rv websites -- I'll check out rv.net -- thanks for the tip. Those honda cables are around $200 now -- if I can make own, I'll definitely do that.locrwln1 said:Doug,
Just so you know, if you go to a RV website like rv.net, you can find the directions on how to make your own cables to link your two honda generators together. I think the honda cables run around $150 dollars and you can make your own for around $ 20-30 bucks. If you go to any of those websites, you can get all of the information you would ever want on generators.
Now having said that, I run two golf cart 6volts in series and then to an inverter to run the microwave, hair dryers, toaster, computer, tv and coffee maker in my cabover camper. I then have a solar panel on top to recharge the chassis (single 12 volt) or I can switch it over to charge the 6volt batteries. I don't have A/C and my set up wouldn't run one, but for every thing else, it works great and is SILENT.
later,
Jack
I learned the hard way that unexpected things happen when my trailer starts to run low or out of battery power -- the worst, for the wife and kids, is that the blower on the heater no longer works...no blower, no heat. Also, the LPG detector started acting up - that was odd. The quick solution was to hook the trailer plug back in and spark up the cruiser. That worked to recharge the 12V trailer battery, but not the optimal solution.
