Which fuse turns on with ignition?
Hey guys, I need to find out which fuse turns on with ignition? Are there any unused fuse spots in the vehicle fuse box to which I can use an add-a-circuit so that I can wire in my blue sea fuse block?
simple fuse blocks....HA!
hey loud, thanks for helping me with the LEDs for my interior, but once again I am thrown off by the sarcasm that may come from your comments lol
Is that pic really a pic of a simpler fuse block to install?
LJ,
I get you are adding a blue see fuse block... but what for? I ran one directly to the battery from the rear... but I have a fridge and needed it powered 24/7. A pretty elegant solution that I will eventually install in the engine bay is this:
https://forum.ih8mud.com/merchandise-storefront/352802-auxiliary-fuse-relay-panel.html
Here is the thread I used when wiring mine. Maybe there is some helpful info for you in there.
https://forum.ih8mud.com/100-series-cruisers/86714-accessory-relay-always-power.html
LJ,
thank you! That write up really helps! Maybe we can meetup to wheel (once I get time off from schoo) and talk more in depth about this topic
I had a Hella 6 fuse block that I had 3 hot and 3 switched on. IIRC I took power from the seat for hot and radio for switched. Ran the block straight to the battery with a fusible link in the line.
is this what you have?
Hella Splash Proof Fuse Blocks H84960071
When I tried to swap my new battery from my old car in the Lexus, I didn't notice that the poles were swapped.
A few sparks and I blew the 140 Amp fusible link. Also the fuse of the radio and another were gone.
When opening the fusible link block, I notice there is 1 fuse missing: the 100 Amp Main.
Any idea if this is needed?
I just bought the new 140 Amp from Toyota, ough.
LJ, that is a Whelen PCC8 switch block/light controller. Plug 'n play type of install, great for having a central control for all of your off road lights...but not stout enough to run a fridge or any of the higher-draw devices (not really designed for that purpose, either). At least I don't think it is...Loud, is your fridge hooked through the PCC8, or something else?
Just depends on what youre looking to power with the fuse block.
Yeah that's what I figured.
