Which 80 has solid axle
Did it come from the factory that way?
-Spike
I'm at least the third owner, but it was owned by a soccer Mom before the last owner. I know the last owner did not change it and I doubt the soccer mom did. I see no evidence of it ever being altered.
sadly no, but i'd be curious to see some photos of the front knuckle housing/ rotor and caliper and the t-case if you ever get them exposed. I've always wondered whether the poverty packs got the 93-97 rotor/caliper or the smaller 91-92 setup, and whether they got the viscous slip t-case or the other one. my fsm mentions both t-cases.
The brakes and rotors are larger. The knuckles do not have sensor holes and the birfs do not have exciter rings.
The transfer does not have the coupler.
correct me if I am wrong ( i am sure someone will)
I thought all landcruisers (back to the beggining of time) had/have solid axles
(Except for the newer 100s :frown: .......the beginning of the end, so sad)
better look after your 80......it might be your last.
There are a Land Cruisers sold around the world. The North American market only receives some of them. In the past they were mostly solid axles in the front but that changed with the 90-Series which we didn't get. We also didn't get the 70-Series but I think they were all solid front axles.
FYI, there is a solid axle variant of the current 100-Series; called the 105. These are sold in Europe, Australia, Africa, the Middle East, and probably other places. Who knows if Toyota will make solid front axles for other markets after the 70 and 100 Series end. Personally, I think they will but we likely saw the last imported to the North American market back in 1997.
-B-
Random Musings about 80s...
-B-
If Toyota were to import a full spec 80 with every factory option seen anywhere in the world (fridge, rear air, lockers, filter clog, solid axles, ambulance or regular doors, aux tank, etc...) into the US at $70,000, how many of us would or could bite?
I would drool on the windows while they sat on the lot, but I'd have to wait 5 years for them to depreciate down under 20K.
The high $$$$$ sport utility market in the US has leaned away from real trucks and towards froo froo junk. Manufacturers have realized that the vehicles sold to the soccer mom and Dr. crowd will never leave the pavement under the first owner.
It may be a long time before anything like an 80 will be offered on the US market again.
If the laws stay the same, from what I can tell, in 2021 we should be able to import the then 25 year old 1996 FZJ80s that are being driven in the middle east. I'll be 52.
Maybe, by then, a middle east vacation will be a more mundane trip than it is now. A 4x4 expedition through there sounds like a trip of a lifetime. Especially if you could bring the truck you did it in home with you.
Merry Christmas everyone!
Mr. Grench (Not Grinch. No relation.)
Ok guys. Will admit now that I'm a new LC owner and don't have all that much experience with these. And the last time I had a 4WD was when I was in college and had a 1972 GMC Jimmy.
Why are the solid front axles so desirable?
Suspension articulation, ruggedness, wheel travel, ease of adding lift to the vehicle.
-B-
better extension and at least one front wheel is on the ground at all times giving you better ride and steering on rough roads. on an independent front suspension it is possible to have both wheels in the air at once. you can overcome that with a lot of suspension mods but a solid axle is great out of the box.
How would one accomplish having both front wheels off the ground?
I can see a high center.
I can high center my SFA perhaps even easier than a IFS.
A IFS has far less unsprung weight for better high speed manners.
It is not as durable or flexible offroad, Baja trucks have overcome this as IFS is much better at high speeds. Walker Evans tried using IFS in rock crawling last year and went back to SFA later in the year. I don't know exactly why it didn't work for him.
ok, well i always understood that on rough roads both front wheels on an IFS truck can simultaneously be stuffed and lose contact where a SFA would pivot to keep one wheel in contact. happy to learn differently.
A SFA has far less unsprung weight for better high speed manners.
It is not as durable or flexible offroad, Baja trucks have overcome this as SFA is much better at high speeds. Walker Evans tried using IFS in rock crawling last year and went back to SFA later in the year. I don't know exactly why it didn't work for him.
I think you have things a little bit backwards.
I fixed it.
Thanks
Got a little mixed up in the TLAs.
Semlin,
A SFA is MORE likely to get wheels off the ground in a high speed bumpy road because of the higher amount of unsprung weight in the front end means they react more slowly.
I personally like rock crawling more than anything, so SFA is the only option for me. Solid axle is better for rock crawling because of articulation (one tire stuffed, the other tire dropped). It is also more stable due to the unspring weight. And, in most cases, much stronger than IFS due to the lack of weak stress points.
IFS reacts faster due to the lack of unsprung weight, is most times smoother, and has better road/highspeed manners.
Most of the benefits of IFS aren't necessary for the industrial/hardcore crowd, so IFS is looked down upon.
