Very cool man, I hope to have my hydro assist in, in about 2 weeks...
P.S. dint know you could tap the 60 box like that. I am running an 80 series box and tapped it like the IFS....cool to know.
Be careful how you mount that welded ram...
You'll want to oppositely twist the tie-rod ends so the tie rod won't torque, a buddy ran a welded one like that the side load from a rotating tie rod scored the inside of the ram to beyond usable within a year...
Can you run that by me again....I'm a little fuzzy on the details. I understand why the side load messed it up,but what do I want to do with the tie-rod? oppositely twist it?
If the tie rod ends are aligned, the whole tie-rod can rotate. If you loosen the jam nuts and oppositely twist the body of the TRE's as much as possible, this rotation is limited.
This pic from the trail-gear install guide somewhat illustrates what I'm talking about.
If you have a crossover setup where the draglink connects to a tie-rod end or the tie-rod, this is a common practice to reduce slop in the steering, as the draglink will rotate the tie-rod a few degrees before actually steering left or right.
None of this is a huge deal with a heimed ram, but I'm just trying to caution brokenparts to be careful installin that ram, as my buddy was not and his ram did not last very long.
Gottcha...Thanks for the info, I have marlin hy-steer steers which are identical the TGs. I hope to have my ram by next weekend.
P.S. you making it to Tellico? for GSMTR...
:whoops:
