I am almost certain that my headgasket is blown on my '92 FJ80. I will test it for sure with a leakdown test but all signs point to a blown headgasket. I replaced the thermostat, water pump, radiator, radiator cap, and all heater and coolant-related hoses with new OEM parts. I am still having a problem with coolant boiling over from the recovery tank even when the engine is nowhere near overheating.I did a bit of research and it looks like the 3FE, while being an incredibly robust and durable engine, has problems with cracked heads IF the headgasket blows. I am anticipating not being able to re-use the head. Where might I find a good replacement cylinder head for a 3FE? I will be going with OEM for the head set and head bolts but I am wary about the cost of a new OEM head (actually haven't even looked into it). Any and all advice on replacing/rebuilding the head on a 3FE would be much appreciated. I will be rebuilding the injectors while I am in there.
