Looks like I don't have that bracket either...
IncomingPics are in order
The first picture is under the intake, the second pictures the absence of the bracket/brace illustrated here:![]()
I don't wheel super hard but it seems like a piece of support.
Well, the bracket is a good idea, it stabilizes the mass of the intake from vibrating around.
You are right, the 1st pic clearly shows the fuel filter is MIA. You'll need to follow the hardline (hose??) that comes of the rear of the injector rail to see where it goes. Possibly the PO cut the banjo ends off the hardline sections and hoseclamped to hoses to a relocated fuel filter somewhere else. Maybe the PO adapted things to a generic/cheaper filter etc. You'll need to explore where the hoses go to find out what has been done... Good luck
cheers,
george.
@HAAANK -
Looks like you can add "fuel filter delete" to your sig along side your fender flares!![]()
Did you ever find out anything more about this?Done!
was under last night trying to find if it was relocated any closer to the tank. Looks like the answer is no. Got paid today so order going in to beno for the fittings. No telling how long it's been off the truck. I was originally looking for it to swap in a new one as my rig is hesitating while accelerating...when it rains it pours, ha ha......
^ so the PO cut the hard lines (that have the banjos on each end of the filter and just run some hose to connect the two ends together or what??
cheers,
george.
Seems possible that your injectors are clogged since the fuel filter was deleted, might have to pull them and send them in for service.
