where does this wire go. rebuilt engine
Las vegas
Need help finding out where this goes.
Just got engine back from machine shop and they took forever I forgot where this goes. Located Drivers side by motor mount. And fuel filter thanks for all the help you guys give.
That is the ground for your engine harness. It connects to the lower half of of the intake manifold in a tapped hole that faces the firewall. Not hard to locate because that connector reaches it with little to spare. Cheers
you can hook it up anywhere really. mine is on the side of the head. it just needs a good connection to the engine.
Awesome. I thought for sure it was a ground but then it's so clean not corroded. I was getting to worried and thought I would ask.
Okay right by the pesky heater hose pipe
Sounds good
