Where does this hose go?
Omaha, NE
As I collect parts and do minor upkeep getting ready for spring I saw this little bit of hose not going anywhere. Could someone please give me a hint? I can't find a good picture of the engine bay to compare or a vacuum hose map. Thanks in advance!
Cory
There should be a vacuum hose map on the hood...
No idea. I removed all mine.
I think it goes to the throttle body down below. I almost forgot mine when I had taken the TB off for the VC gasket.
I was thinking the same thing...
Still stumped on this hose. Can someone please post a pic of there engine focused on the vacuum hoses by the intake I would greatly appreciate it.
Thanks,
Cory
THIS recent thread has a lot of good pictures, might help.
looking at the thread with the pics. i believe that hose is on the lower front portion of the throttle body. probably can see with a flashlight. if you can't get hands in to put back on - use a pair of long reach needle nose pliers - i did this when I had to work on some of the coolant and vaccuum hoses up in that location.
DSC00569.webp I believe it is this one. Starts near fuel pulse damper toward front of engine and goes toward back of engine and slight left under wire bundle.
DSC00566.webp Ends up under cylindrical black solenoid attached to throttle body and next to valve cover. you can just see the spring hose clamp under there.
